I fired up my radio for the first time in a year or two and I noticed that on both the radio's built in power meter, as well as on my external meter, my power output is only about half of what it should be.
I then checked the SWR and noticed it to be way up from what I remember it being back in the day. Today its reading 2:9:1 across all 40 channels, while I recall it being about 1:4:1 previously.
(I tried removing the external meter and short coax extension and plugged the big coax directly into the radio. That didn't change anything. Output only about half of what's expected. Tried another radio too..same thing, only about half output. So I attribute this to the high SWR.
The antenna is a Maco V5/8 Vertical. Its been up about 20 years, with no problems. What causes the SWR to go out of adjustment like this on a base antenna??
