I noticed taking a cobra 29 out of a truck with low swr and hooking up a Stryker in its place to the same antenna the swr is higher. You always read your tuning the antenna to the vehicle not to the radio but I think I disagree. My question is should the swr be checked with the 20 watt dk power wide open or backed off to around a 4 watt like a normal cobra 29? Wide open I’m showing 1.5s on both ends and about 1.3 on 20 but with the power cut back the swr meter needle barley moves off 1. I know it’s in good shape either way but was just curious if it should be set wide open or on low power.
