T
thumbs1
Guest
Ok I'm still wet behind the ears but what's up with the SWR readings. Most of the time they read around .5 sometimes lower. On occation they will get up to about 1.0. Why the change? Is it atmospheric conditions? I can happen in a short period of time but while drivein it can change. Has it to do with location. If this is the case how do you know you have you antenna tuned it's best?
What's up with that?? ;-}
thumbs........Souderton, Pa.</p>
