I have a 06 trailblazer now I tried 3 different antennas now my trouble SWR won't go below 2 not sure if it's the metal that is made out of.I tried the magnet mounts and a fender mount I don't know what is going on.Any help would be great
run a wire from your - battery post to the the antenna mounts..
Beg, borrow or buy an antenna analyser to see what's going on - you can get cheap NanoVNA ones for under $50. If you've a very good RF ground you can find that because manufacturers make antenna lengths assuming it'll be installed with a crap RF ground like the majority are, that it's actually resonant below the CB frequencies out of the box as the more efficient the RF ground the shorter the antenna needs to be for a given frequency. If your SWR on your lowest channel is lower than the SWR on your highest channel then this does indicate this is what is happening.
The problem with trying to do it with just a CB if you've the issue above is that even on the lowest channel it doesn't go low enough in frequency to the point where the antennas lowest SWR is.
I'm lucky that I have an analyser and every CB antenna I get is usually resonant around 26MHz out of the box and I have to cut them down. The Sirio 5000 I have I had to cut three inches off. You don't want to be shortening them by cutting them until you're sure that's what the situation is.
@ForestRunner98 Nice Job...
You see where you are "at" on the "Smith Chart" background?
You have an ever so slight "+j" component along with a impedance bump the antenna cannot be used to compensate for - Your SWR "Circle" and loop back shows this.
No matter what though - you're nearly spot on - and with some CB Radios with built in SWR detectors - this would have not even "moved" a needle even with the SWR CAL knob cranked for full sensitivity.
Just fun to watch you work - you're doing great!
You've come a long way - your family should be proud of you
the vna is also providing information about resonance. the 24.4 nH figure is indicating that the antenna is inductively reactive yet close to resonance but a bit too long @ 27.200 mhz.. resonance is somewhere just below that frequency. 24.4 nH = .0244 uH. in the case of a loaded antenna this adjustment will be "touchy" but it would be interesting to slide down below 27.200 mhz. to verify,. this can be confirmed as the 24.4 nH. figure is reduced. swr will drop slightly to 1.2388:1 when the inductance is cancelled at which point the (load) antenna becomes a pure resistance. good work.
