I have an Autec swr/power meter in line w/ radios.
AL is Maco y-quad, boom is about 15' above the roof, 38' above ground, heading 55*.
optima mk3 am dead key barely moves the Autek swer meter 27.385 am, same with a Galaxy 949.
switch to lsb and xmit with both radios, same thing, swr 1.125:1.
mk3 does not have an swr meter but the dx-949 swr meter was agreeing with the Autek.
enter the ranger 2970 n2. Set to 27.385 am. dead key about 10W swr bearley moves. switch to lsb and xmit , boom swr swings out to 4:1, yikes!
power was set down to just above minimum with mike gain 50%. Switched on the swr meter on the radio and nothing! not a single bar. I removed the meter and the swr meter on the radio registered nothing.
I'm apprehensive about using it with these meter readings.
your thoughts?
your thoughts?
