I miscalculated a recent antenna install "base" by ordering 50ft.of LMR-400 and ended up needing 60ft. When temporary set up in the basement I had a perfect swr of 1.0. I later lengthened it with a barrel connector and ten more feet of LMR-400 all connectors etc are factory and supposedly top quality " I certainly paid for top quality" but anyway I now have a swr of 1.3 and with a few hundred watts flowing through the meter 1.7 with audio raising it even higher. Is 60ft. a bad length causing higher swr or is something else the culprit?
