B
BOOTY MONSTER
Guest
got some noalox and figgured id use some on my 10k . im wondering if the actual coil wrapping comes off its black former/shaft section though . i got the lil hex screws out the top and bottom . but . using just hand strength i cant get the coil to budge . i wanted to take it all apart for a good cleaning and then reassemble with the noalox on all connections .
will the coils come off without damaging them ? or are they press fitted or something that either i need something special to remove them or that ill most likely dammage the antenna trying to get them off ?
im not expect any performance difference , just want to do a good cleaning and reassembly for a warm fuzzy feeling .
thanks .
thanks .
