Click here to find out how to win free radios from Retevis!
ok d115 is located by IC19 on the right hand side of the radio down towards the front.. if you go from the bottom of IC 19 to the left you will see it right next to C219 an r228 an r 230
D78 is located by D115 just up a little an to the left more.. it is by c298 an T1.. hope this helps..
you can try putting a resistor in lince with you jumpers that might work but other than that i dont know, i left all the ones i did the way they where..
