I did your project used same parts vu meter will not budge any help will be apreciated, im i missing anything else. what kind of vu meter is required?While I love the Sinad software meter you can get for to run on your computer you can also build a homemade RX test meter using an VU meter.
Parts you will need:
1- VU meter
1- 8 ohm 8RΩJ 20 watt Axial Ceramic Cement Power Resistor.
1- 1/8 inch Mono plug
Some small wire to hook it all up.
Here is what mine looks like:
I also added an S Meter to watch both while setting the RX cans to keep things in line. Very easy to build and use with your signal generator. Yeah its was all put into a cottage cheese bowl. I was lazy and cheap! LOL.
You did remove, consume or just plain enjoy it's contents before you did this - right?
I have no idea what the point is to use a meter movement You can't call it a sinad - that's for sure. Sinad means 'signal vs noise vs distortion'. These things a computer can see and judge between these signal shapes. This is why it is imperative to feed a clean, properly formed sine wave signal into you receiver so that when computer's sinad program is run that it can see anything that is the same clean sine wave coming thru the receive stages to your audio amp to the speakers. A simple meter cannot see that. A o-scope can - tho. But a sinad is best for this function.
When adjusting the receive stages, it is imperative to have sinad giving you the clean radio of signal vs noise/ distortion, because it is too easy to over peak the receive signal. When this happens, you experience receiver overload. Which means that strong incoming signals will sound distorted due to this overload. Sinad won't let that happen if you use it as instructed.
Best advise for those considering receive alignment? Leave it alone! Keep yer grimy mitts off - lol! Unless you do it right you will only screw it up. Been there; done that. It takes time/experience to learn and is a little bit tricky to align receivers; is not something a jackleg mechanic can do.
The sinad program is not complete; it won't work w/o a sig gen. Read its requirements, it is not a stand alone product.
Like I said, better to leave it alone unless you are willing to understand what happens to which coil when you start twiddling the cores. That is all I'm going to say about that, since it gets too lengthy to go into the details - unless oldtech03 or handyandy or someone else wants to pick up the ball from here and run with it.
