Hi Gang,
I am aligning a TR966 which has the same board as the Galaxy 949. In the PLL alignment instructions all is good until the last 2 steps. That is the USB and LSB TX OSC alignment. The instructions say to attach to TP6, transmit the radio and align to a specific frequency. When I place the radio in TX it does not trigger my freq counter (HP5370B- calibrated). I am unsure how to get it to trigger. I tried adding the double tone, no luck. I tried re-installing the bias jumper, no luck. I am sure that there is something I am missing or the instructions are incorrect. I already found one issue where it was asking you to set the transmit freq offset on channel 1 am and it was supposed to be channel 1 LSB. Has anyone aligned one and know the "trick"?
Thanks in advance!!!!
