Texas Star amps...
Oatmeal
484
78
38
West Virginia..
Ive been told these amps are considered to be clean as running a amp gets...
So, next step, like to know what these amps does..
Dead key watts, and swing watts...
TS 400, 500, 500V amps..
The amp would be used in a base setup, on a ps of course..
Not looking for dosy watts, more a long the lines of what each amp actually does on a Bird meter...
Texas Star amps will deliver what they specify if you have the drive power they call for. As far as being clean, they are biased in the AB method and running push/pull has harmonic suppression built in.
I always recommend a low pass filter between the radio and the amp and one after the amp. You will have minimal harmonics going out.
Reactions: Oatmeal and Crusher
