hi all,
just thought id post on my latest antenna homebrew project in case anyone else wants to build one.
i was looking for a 102" whip style antenna that i could tune, and it had to be something that i can take apart and put in the 6' bed of my truck.
this antenna is not for use while in motion! its for sitting still DXing in my truck.
something i spend a fair amount of time doing these days due to my job.
it also had to be cheap, and the materials easily available. (so others can try it)
here are the materials i used: (all purchased from homedepot)
1. 72" length of 3/8 x 16 all thread. (make sure its straight)
2. 10' piece of 1/2" EMT conduit. (the thin wall stuff. make sure this is straight also)
3. 3/8 x 16 coupling nut (approx. 2" long)
4. 3/8 x 24 x 1" hex head bolt
5. 3/8 x 24 nut
6. 3/8 x 16 nut
7, 3/8 flat washer and 3/8 lock washer
total cost was under 11.00
first i cut the conduit to 48". then i ground down the corners of the 2" coupling nut until it was basically rounded. only do this to one half of the coupling nut. leave the other half as it was.
once the coupling nut would fit nicely inside the conduit, it was welded in place.
this left about half of the coupling nut sticking out above the conduit.
this is the end where the all-thread is screwed in.
next i prepared the base assembly by first grinding down the corners of the head of the 3/8x24 bolt so it would fit inside the conduit. then i put a 3/8 washer on, followed by a lock washer, followed by a 3/8x24 nut.
this was tightened securely.
next the head of the 3/8x24 bolt was inserted into the open end of the conduit and the conduit was welded to the washer.
now you have a 48" length of conduit that can be screwed in to any 3/8x24 mount.
next a 3/8x16 nut was threaded on to the all-thread so that once correct tuning is achieved, the nut can be cinched down against the coupling nut, thereby keeping the all-thread in place.
the all-thread is then threaded into the coupling nut until the desired length is achieved. (approx. 108" for me)
thats about it! i do want to add some sort of corona ball on top, but that will come later.
the antenna i built should tune from 24-30mhz and beyond.
i have not gotten to do any testing with it yet, as i barely got done before work started.
tomorrow i will do some testing and post the results.
the only issue i can see possibly being a problem is the shape of the all-thread itself.
because of skin effect, im not sure what effect the "jagged" outer shell of the all-thread will have.
anyone who is knowledgeable about such things is highly encouraged to post here to put my mind at ease. LOL
oh, and yes, my mount is on the roof of the cab of my truck, and it does have a backing plate added for extra support.
thats definitely something to consider when using this antenna on a windy day!
5. 3/8 x 24 nut
6. 3/8 x 16 nut
