I hear a lot about the Penetrator 500 5/8 ground plane antenna. I have been using mine for about 15 years; it has been a very user friendly devise, not much to do as far as maintenance but a lot of gain in the transmit and receive department. A lot of talk I see about the changes in measurements with the change from 23 channel and 40 channel radios. The only measurement I have not seen and I understand it has not changed, is the length of the Matching Rod (part #170774) and the Beta Rod (part #170775) I believe this could be important to the ones trying to achieve a good SWR on 27 MHz. I myself would appreciate an answer, my antenna was hit by lightening taking out the matching rod like a built in fuse. I have manufactured two of the rods and have not been successful; I only have the picture in the Installation & Operation Instruction manual to go by. Does anyone have these rod lengths? Thanks
