Talked to a guy today that runs one, and he said it looked like the updates for him were mainly for split operation. Not sure if there's more features added or not?
73,
Brett
I should have seen that. Knwd did the same thing with the TS-570. I bought the TS-570SG which added DSP CW filters and 6 meters. They had four versions, The S, D, DG and SG. Looks to the same deal with the 590; adding features and letters after the model number to designate what was added. The TS-590S is very similar looking to the TS-570S.
Sounds interesting. Hopefully the low average output power has been addressed by Kenwood in this new version.
The Yahoo groups aren't aware of it.I believe they fixed that quite a while back.
73,
Brett
How and when was it fixed? I know the software updates never resolved it.
Were they modified when Kenwood undertook the overshoot hardware repairs?
OK, Brett.I don't know about Yahoo groups, but I read it quite some time ago. IIRC, Kenwood even put out a notice for what point in serial numbers that the issue was corrected at the factory.
http://5tx.de/?p=1283
http://5tx.de/?p=1350
73,
Brett
OK, Brett.
That relates to the ALC spike issue not the low average problem.
Hopefully the average power has been improved on the new version.
73s
There is NO low average power output problem. People think there was, because of a misunderstanding on how the power output meter reads. Even though it is an LCD, it still reads average power, NOT PEP. If you hook one up to an oscilloscope, you will see this.
There is a problem with low average output power.There is NO low average power output problem. People think there was, because of a misunderstanding on how the power output meter reads. Even though it is an LCD, it still reads average power, NOT PEP. If you hook one up to an oscilloscope, you will see this.
