I found more information on web.
Jay in the Mojave wrote :
I would say they are worth getting, many times people just want them
off their roofs. I have several Penetrator 500 5/8 Antennas, But one is
a product of being made from a few, and its in great shape.
The Upper and Lower Plastic Insulators, and the Plastic Tuning wire
Stand-off's are still available from Hy-Gain, for only a few dollars.
The Tuning wires can be replaced by Tinned 12 or 10 gauge wire. The
Top-Hat Assembly can also be easily repaired, with 1/8" OD Aluminium
Rod.
One of the biggest problems with the HY-Gain Antennas, is that Hy-Gain
figured a very smart way to make there antennas resilient, meaning
strong but flexible. They do this my "Reduce Swaging" the Aluminum
Tubing, reducing the tubings OD & ID size, to accept the next smallest
Tubing size, in 1/8 OD increments. Such as necked down brass riffle
cartridges.
Example: Their 7/8 inch OD / 3/4 inch ID tubing is Reduced Swaged to
accept 5/8 inch OD tubing. This Reduced Swaging saves them big money in
material times a gazillion antennas, Very shape indeed.
However if the Penetrator 500 Reduced Swaged Tubing is damaged, it can
be replaced with the same size OD tubing, and a short adapter can be
installed to allow the next size smaller tubing to be installed, it just
takes a extra hose clamp. I have repaired many Penetrator 500's using
this technique. The only exception that I have run into is the 7/16,
that is used ant the end of the vertical element, and the end of the
ground plane elements. A piece of 1/2" OD x 72 inches long, tubing can
be used, but the Reduced Swag on the mating end of the 5/8 inch tubing
will have to be cut off a few inches. NO big deal.
The Penetrator 500 was the only CB Antenna that I know of that was rated
from the manufacture to handle 1500 watts coming out of the gates.
Ten-4.
I am sure this was the result from Hy-Gain getting some heat from the
antenna users, that where burning up their CLR-II 5/8 Wavelength
Antennas, that had a Mickey Mouse Impedance Matching Coil on a small
circuit board. I am sure the power from the Hy-Gain Linear Amplifiers
was enough to take out the CLR-II Antennas. Which drove the 1500 watt
rating for the new design Penetrator 500.
Jay in the Mojave
