The questions of the year isn't it?
Many of you have already helped me get this far but as usual I have more questions.
I need the "perfect antenna" for dx. I currently have a 40 ft tower braced to the side of the house to use. Currently I have an imax which makes a decent trip but I'd like to be able to focus a bit better to make those trips.
I have been called cheap in the past so I dont want to spend a LOT of money, but do want to get one that is decent quality and will last for a while.
Sideband obviously will be where I am going to be using the most as the IMAX will become the "local" antenna. For power I hope to keep it under 100w and at most it will be 500w so power handling should now be much of an issue.
Input?ideas?fav antennas?ones you wish you had?things you do have?
help out a newbie!
thanks all...Jeff
</p>
help out a newbie!
thanks all...Jeff
