So when I go up to my mother inlaws place a convient ground plane I can just chuck ont he ground for 10-11 meter use.
It will be built from stuff on hand. So probably 108" whip, some Francis 2 or 3 foot fiberglass wound antenna's as radials, some angle brackets, maybe some aluminium on a piece of plywood etc.... I amnot going to hual an antenna tuner with me and the radios I will be using will not have built in tuner.
I have not built an antenna tuning network into a home brew antenna before. When matching the homebrew antenna does the network always have to have capacitor and inductor?
To be honest and upfront I have not looked inside my ARRL HANDBOOK and I do not own their antenna book. I just thought I would toss this out. This way I can be in the wood heated garage and toss my coax through the dog and cat door and be toasty warm when visiting instead of in my wifes vechile with a magnet mount on top.
I amnot buying anything at all. I thought about magnetic loop but trying to run one that I could build with what I have on hand would be at the 100w input level would be diffacult and tunning would be a chore trying to cover 10m-11m. Plus constructing it in such a manner that it is compact and easy to take downa nd put up would be an issue.
Oh I live in Michigan and once snow flys anything that you need to anchor to the ground or drive into the ground is a no-go. The ability to just set it on the ground and go is a huge factor. On top of that it would also allow it to be tossed into an attic, onto a balcony, onto the beach, in front of your sofa or bed almost anyplace that a 108" SS whip wont hit when placed upon the floor.
Down the road I want to build a magnetic loop just to do it. I have built plenty of Dipoles but those are a pain for stealth use when traveling. I know my homebrew should be able to outperform that dreadful FireStik indoor base antenna but that is kind of the idea though. Obviously the 108" SS whip could be replaced with a teloscopic antenna for the best portability.
What I have kicking about:
2x 108" MFJ SS Whip Antenna
4x Francis 11m fiber glass whip antenna
3'x3' aluminum sheet 1/8 inch
lots of solid copper Romex house wire to use to make inductor
lots of jelly bean electronic parts but would happily purchase specific capacitors if need be
lots of hardware and scrap lumber and plywood
My bigest concern is that the built in matching network be able to live outside with the antenna in all weather from 98°F Summers to -28°F Winter and all manner of percipitation!
If someone has already tackled this a ready plan to follow would be great with known proven outcome but it is the matching network that I am really in an area I have not played with before.
P.S. I do intend to dust of my ancient 1999 ARRL HANDBOOK and see if the info I need is inside of it.
P.P.S. Thanks in advance!
