Set up: Galaxy 95t2 with the output impedence matched for amp, TNT 600HD, Dosey TR1000, 102" antenna on a hustler ball mount, spring, and 1" riser at the top of the front bedrail, directly behind the center of the cab on a Silverado 2500HD. Entire truck has been bonded with tinned copper straps. Using Times Microwave LMR 200 coax.
With the amp off my radio and external meter (mounted after amp) both read 1.5:1 across the 11M band with the amp off and radio at full power (50W dead key).
Power turned down on the radio with the amp on so the amp is dead keying 150W out. External meter reads 1.25:1. I have seen and heard of many people have SWR reading increase after the amp is turned on. This is the first time seeing or hearing of a decrease. Curious
Not that I'm complaining, lol
