Well I was tuning through 20m this morning and caught a QSO between a W1 and a G0 and the W1 had a really noticable echo on his signal. :shock: I thought GREAT just what we need. A 20m CB'er with an echo mic and God knows what the signal looks like on the band. :roll: I was about to tune away in disgust and decided to check propagation to the west.The tribander was pointed northeast at the time. As the beam swung around to the west and southwest the echo on the W1 station became fainter and fainter until it disappeared completely.It was then that I realised what it was.Backscatter. His signal was arriving at my QTH direct from the USA as well as traveling over to the U.K. where a portion was being scattered and reflected all the way back to me again along the same path the UK station was beong heard. The time differance of arrival was what was causing the echo.With the beam pointed to the UK the echo was really bad.I have worked backscatter before but usually just in a situation where you point the beam south to talk north and can't hear the other station on the opposite heading. I remember hearing CB'ers talk about hearing hams use echo mics on the air and I have to wonder if they heard the same thing and thought it was the mic instead of propagation.The only way to tell is by rotating the antenna and listening for a change.
