Actually I already have a prototype made up from my wire dipole. I just folded the ends at 90 deg. use zip ties at 4" and made the reflector to proper length for ll meters. I set it up using wood stakes on the ground about 2 ft up and had a perfect match, however didnt get much but a couple local reports on it. I have a few thoughts and questons.
-How will this compare to my 5/8 groundplane antenns which seems to work great right now. not sure what gain it might have if any over the 5/8 and is a simple single element moxon an upgrade?
-can a moxon be used vertical is there an advantage to it over a 5/8 GP
I dont have a tower or and roof mount is out of the queston, trying to keep stealthy. current antenna is in a tree, thinking of trying Moxon in the tree about 20-30 ' up. It would be fixed to the Sor west for trial and as an alternative horizontal to my 5/8 vertical
