I have no experience with high-voltage in relation to Radio, although if anyone has any thoughts or experience with the LDMOS Amplifiers using BLF188XR or similar devices please share them here.
The 50v power supply is my first challenge, these parts are much more efficient than the typically used (almost extinct) 2sc2879 although they require higher voltages. Newbie question: generally speaking a switchmode powersupply will not handle the current demands here?
Searching fleabay I find two post of interest I wish to bring into discussion:
LDMOS BLF188XR BOARD LINEAR AMPLIFIER
Source Country: Israel
1.2 KW LDMOS power amplifier 1.8-54MHz HF for BLF188XR
Source Country:
Russian Federation
I don't have the experience / confidence yet to save up some cash & buy one of these boards, just to pain-stakingly rip it apart piece-by-piece to reverse engineer it and measure / record every component
and document every trace, just to get a blue-print.
My concern form using the board as-is, the material used does not seem thick enough! I want to build this unit like a Tank, Rugged. The goal is to build an lmdos unit that will "loaf around" @ under 1 KW, use a board easily sourced (or improve upon one that's available currently). So this little pcb doesn't meet the demands, it looks way to thin. Hence reverse engineer it just to build it "stronger", more rugged. Also this project is for information/ experimentation/ research & will NOT be another 11 meter splatter box shooting harmonics to the moon, a proper filter and dummy load will be used.
Source Country:
Russian Federation
