Thank you Doc for your analyses. And let me quote you:
“So basically you're saying that your antenna does work and that you have happy customers. Good for you, and good for them. But 15 dB better that some other antenna? I can believe that too. But just exactly what other antenna is it '15 dB' better than, and what kind ‘a 'dB's are those? You can call proven characteristics 'in the box', or old fashioned if you want, but those proven characteristics do make things better, are more efficient. Hey, them old fashioned thingys do work, work well, and sorry, Your 'out of the box' 'new style' invention only 'works'. I'm happy it has a low SWR from day light to dark, but that's an almost meaningless claim. First you have to understand how important SWR is, or isn't.
Hope you sell a thousand of them, happy trails...
So Doc, This is off the cuff as I do not have a lot of time to hang out on the blog as I have orders to fill and ship.
The 15 dB came from a guy 3.5 miles away using a QRP station. I do not know how his radio’s meter is calibrated thou his “S” meter gave me a report that the antenna I build and sell was a solid 5 S units stronger than the un-disclosed production Balun designed antenna I used to compare it with. I was on 10M using the same radio, same power. Same type and length of coaxial cable. Antennas are mounted the same height above ground about 45 feet apart and I switched between the two antennas. Band condition was Rock solid. So 5 S units = 3db per S unit = 15db. That was a quick check so it is disputable. More testing is required to make a claim, good catch.
As far as 1800 theory goes, that is good stuff and YES it works and gives the Basis for all future designs. Old fashioned is proven and Like the 1900”s Ford model cars they work and are very enjoyable to own and operate! But todays cars are by far better equipped and are better on mileage, can go faster, much more comfortable, etc…etc…
So thank you for your good wishes and I hope to talk to you again.
Like I have stated in my add, This may not out perform a perfectly tuned ½ wave or ¼ wave antenna built for a mono band (1 band) antenna with a perfect ground radial system. You cannot dispute old perfect theory of the 1800’s. What I do offer is a compromise, all Band, Broad band, Small foot print antenna. That will radiate on the bands as stated with very good results. No Tuner, no Balun. Just a simple RAW radiating vertical element antenna. It will have a good SWR match to your transceiver and handle full legal limit of RF power. This is for someone who wants to get on the AIR with one simple antenna that works all bands. I do not and will not claim it is the best or better than any other product out there. But I will say it is the simplest antenna you could ever have to keep you active on the entire spectrum between 160 Meters through 6 Meters.
Carl
