i think something went wrong with your calculations.
1/2 wavelength @.83 vf is 15.017 feet.
1/2 wavelength @.66 vf is 11.941 feet.
when it comes to coax being an impedance repeater or an impedance inverter, it's really about avoiding the exact 1/4 wave multiples, not trying to get an exact electrical wavelength.
that applies to coax being used to connect an antenna to a radio system.
phasing lines and using the coax as part of an antenna is different.
so, if your goal is to not have an impedance inverter length of coax going from your radio to your antenna, the lengths to avoid for 27mhz with a coax vf of .83 are:
1/4=7.5 feet
3/4=22.53 feet
5/4=37.55 feet
7/4=52.56 feet
9/4=67.58 feet
11/4=82.6 feet
13/4=97.62 feet
staying clear of these lengths will keep you from having a different SWR reading at the antenna end of the coax than you do at the radio end.
