TJ5A HF 20W SSB CW Transceiver Kit and assembled
RX:3.500-30.000Mhz (broardband RX is available by adjusting the jump cap)
Tx:7.000-7.3000Mhz, 14.000-14.350Mhz,21.000-21.450Mhz, 28.000-29.700Mhz
High performance AGC
features strong signal handing ability
+/- 120Hz RIT is available
DDS controlled, LCD display,heavy duty metal case
1-20W output adjustable,rx sensitivity 0.2uV
10Hz,100Hz,1KhHz,10KHz,100KHz tuning rate available
Dual VFO with 40 memories
Memory transfer to VFO
Crystal IF filter 2.4K
RX:250MA, TX:4A
size:180mm wide x 58mm high x 200mm deep, battery case deep 35mm
weight: 1500g without battery
TJ5A equips with a bolt on battery box, enough space for 6pcs of 18650 lithium battery, total 4400mah
TJ5A fully assembled version, comes with custom made speaker handmic
Optional battery pack will be ready for purchase while shipping
Shipment date:1st week of Aug
Price preorder model $399
DOCTOR/795
RX:250MA, TX:4A
DOCTOR/795
