Do companies that build amateur trancivers use higher quality capacitors and components then Builders of 11 meter transceivers?
If a used transceiver (Yaesu Kenwood Icom) is working as it should after 20 years would it be advisable to have it recaped or, go with the old adage "if it ain't broke don't fix it"?
