Hello all.
I saw this Top One antenna for... I was thinking about buying it for a backup antenna.... Does anyone use it or has any experience with it. The add says It is 11.5' tall (Space saver)
This is not SPAM just looking for a good backup antenna!! PICTURE
is it snake oil or a winner.....Top Radiation - This design results in increased range, fewer dead spots. This is especially important where installed height is limited. Radiates approximately 15' higher than most antennas which radiate at the bottom.
Lower Angle of Radiation - Your signal hugs the curvature of the earth instead of shooting your power up into the sky, which means greater distance than an ordinary omni-directional antenna.
