i have a D201 that doesn’t have receive in AM or I can barely hear a tone with volume FCW, works good in LSB & USB. Has power out in AM and modulation. I removed all the tubes and checked and they all tested good. I recapped (electrolytics) the entire radio and all the HV resistors hoping it would correct the issue but no luck.
I looked at the alignment procedure and decided to first look at the 455 KHz AM alignment first. When I put a .01 on V302 pin 2 and inject a 455 KHz tone I’m not getting any audio at the speaker at all. I’m not sure where to look now?
