Most all mobile radios have this specification for the transmitter maximum deviation, +/-5kHz. I want to find out the range of frequencies that a transmitter will cover in addition to the tuned frequency. What information in the datasheets says how much that deviation is at a given power output?
For example, national calling frequency is 146.520 MHz. Tuning the transmitter to that frequency causes the main power output to peak at that 146.520 MHz, and it falls off exponentially (I assume) at nearby frequencies. At +/- 0.005 MHz, 146.515 and 146.525 MHz, power = ?. At +/- 0.01, 146.510 and 146.530 MHz, power = ?. And of course, a higher transmit power causes a greater deviation than a lower power, and hopefully the shape of the peak will be nearly the same just with amplitudes differing.
Maybe "maximum deviation" is not what I am looking for, it might be called another word.
TRANSMITTER
RF Power Output:
55/25/10/5 Watts
Modulation Type:
Variable Reactance
Maximum Deviation:
±5 kHz / ±2.5 kHz
Spurious Radiation:
Better than -60dB
With this information, assuming it is the maximum deviation, what that means to me is that at maximum power (55W) there is a maximum deviation of +/- 5kHz, which happens at 0W. So I could make a graph Power vs Frequency (x) and put a dot at (x,y) (146.520Mhz, 55W) and dots on the sides (146.515MHz, 0W) and (146.525MHz, 0W). If that is correct (that the +/- 5kHz deviation is relative to 0W), then I could continue fit the power output curve as a function of frequency to a Gaussian curve to find out what other frequencies and at what power I would be spilling over to. As opposed to just a square fit, I doubt the power out deviates at full power (55W) across the +/- 5kHz and go straight to 0W there after.
Edit: Sorry, another specific question. Is that maximum deviation relative to 0W or -3dB, -6dB, -60dB or some other "common" reference point? Thanks!
Specifically the radio I am interested in is the Yaesu FT-1900R, but most any other radio has this same "maximum deviation" specification.
Yaesu FT-1900R Specifications
Thanks!
john
TRANSMITTER
RF Power Output:
55/25/10/5 Watts
Modulation Type:
Variable Reactance
Maximum Deviation:
±5 kHz / ±2.5 kHz
Spurious Radiation:
Better than -60dB
Thanks!
john
