TRANSMITTING
doctor
Supporting Member
I Support WorldwideDX.com!
Aug 1, 2006
1,036
80
58
81
indiana
I have downloaded agwpe and some programs, I have them set up right<hopefully>, but never can get the things to xmit, from the pc to the radio..
used a signal 1 interface or a donners, any suggestions..
DOCTOR/795
We need some more information. What rig are you using? Is this on VHF or HF? Have you tried any other applications besides agwpe? Can you tell us exactly how you have the interface and software configured?
The rig is a yaesu ft857d
The agwpe is set up hopefully correctly, using mixw.
No xmit from pc to radio with this program, and no receive..
Thoughts
com port wrong?
firewall blocking?
am using a DONNERS interface..
At the moment trying to use on vhf packet.
Any thoughts
DOCTOR/795
All of the above!
Your firewall should tell you if it's blocking Agwpe, check the log.
That Donner's interface is one I'm not familiar with, so it could be a problem. I'm assuming it's a USB thingy?
Make sure the sound card is getting a signal. You can check that easily with Agwpe by opening it, clicking on the port and then the little green square thingy in the top line. That opens the sound card/Agwpe 'level' window, check if the level is high enough or if there is one at all.
Post this same question on the Agwpe forum, sorry don't know the address off hand.
I don't know anything about that radio so read the manual about it's characteristics/abilities.
Ask George, SV2AGW if he has any suggestions, he's very helpful.
I can't say I've used Mixw with the Agwpe so checking all the port selections in Mixw and Agwpe isn't a bad idea.
If/when you figure out what's wrong, please post it, cuz I might run into the same thing.
Good luck.
PROGRESS, I am receiving on cw now, conditions poor for hearing much else today<t-storms>, now to get it to xmit.
DOCTOR/795
  • @ W4KVW:
  • @ W4KVW:
