Trb-x3 echo board.
Simon666
New Member
Jul 4, 2020
Hi folks.
Just a quick question.
I have a trb-x3 echo board that up until recently had endless echo if wanted.
It has now gone funny where the endless echo no longer works.
I’ve read the instructions over and over and can only see the set up section shorting coach shield and j2 black wire temporarily to set.
Anyone had this issue.
Many thanks
  • @ Geoexplorer69:
  • @ Geoexplorer69:
