Trying to find default reapeater offsets
TravisW
Nov 11, 2009
6
Sothern California
I know from my reading that 2M band is .6mhz and I thought from my reading 70cm band was .5mhz but I found on another webpage the following and it says 70cm is 5.0mhz:
Band Offset +/-
6 meters 1 MHz
2 meters 600 kHz
1.25 meters 1.6 MHz
70 cm 5 MHz
33 cm 12 MHz
23 cm 20 MHz
How to Use Amateur (Ham Radio) Repeaters- A New Ham's Guide to Repeaters
I'm trying to confirm whether or not 1.6mhz is the correct default offset for 1.24 meter band.
Thanks
You are correct,the offset for 1.25m is 1.6 MHz. Don't forget about the 10m band which has FM repeaters above 29.0 MHz. The offset is +100 KHz.
