TS-590 Computer Control-Audio Control Options
Mudfoot
Elmer
I Support WorldwideDX.com!
Jun 17, 2009
11,071
6,458
698
63
Southeast Ohio
I FINALLY downloaded the ARCP software to control my Kenwood TS-590. I'm still in the learning stages. Just wondering what other owners are using for audio.
PC headset? PC desk mic?
Looking for something decent and comfortable. Kinda leaning toward a decent PC headset combo.
Anyone?
For what it's worth, and considering the requirements about comfortable and a 'decent' sounding mic, I think one of Heil's 'BM-10' boom mic/headsets was the cheapest -good- device I've ever used. That goes back quite a few years though, and my 'requirements' were different than yours.
At one time Heil's stuff was very much 'adequate'! Had a reputation of being both 'good' and 'cheap'...sort of. I'm afraid his stuff isn't so cheap anymore. Or maybe I'm just cheaper?
I'm also NOT one those so-called 'audiophiles'! I think a good mic shold make you sound exactly like you sound in person, I don't need any 'enhancements', I couldn't care less about impressing others. And a 'broadcast' quality sound is just not a realistic idea for CB/ham radio.
So, take this for what it's worth...
And as for PC audio equipment, there's so much variations with that that if/when I need such a headset, I get the cheapest thing I can find at 'Wally World'. Some of that stuff really isn't bad at all.
Turtlebeach headsets are nice and comfortable and because the TS590 has 18 band EQ you can make them sound how you want.
I second the Turtle Beach headset. I use one and it is comfy. Got mine at Walmart for about $60 and it's a nice headset.
Heil Pro Set Elite is very nice.
It has the HC6 cartridge and high sensitivity head sets for low drive.
Your 590 should have audio at a back panel jack that will cut off when the head set is plugged in the front panel jack.
Patch back source to a favorite speaker or audio system.
Check your menu for route setting off the back panel jack.
Once you settle on a mike and head set look at EQing for best xmit and rx audio and save the file to a folder then down load to the user positions in the TX and RX menu settings..
You can also set up two different EQs for both and switch between them by using the A/B switch control on the front panel.
Another trick for those who are interested in AM mode.
Use the MCP to set up a favorite AM frequency.
Click on 'split' so you can program both TX and RX separately.
Set frequency the same in both RX and TX but set TX to AM and RX to SSB.
Save to folder then down load to radio.
Call up the memory channel and test that TX switched to AM and RX is SSB.
What you now have is full SSB filter usage as opposed to the more limited AM filter ranges. Then use your Hi cut to control high end DSP limits.
Any heterodyne is handled by using the RIT to off set zero beat it and B.C., M.B.C. and auto notch.
You can freely switch upper or lower side band to get the farthest away from any interfering signal.
It sure can clean up the RX when others can't hear very well with their wide receivers..
Next tip is to use the MCP to set up the 60m channels and down load to memory channels so they are there "with precision" every time you go there.
Good luck.
