Marconi, I cant believe your asking this ? How have you ever tuned a antenna with out knowing what was at the feed point, without using the 1/2 wave method ?
pruenrg, if I asked somebody a specific question could you give me the question or a link?
Can we agree that if we want to tune an antenna, it is very likely the antenna is not tuned and maybe new construction, the load impedance at the feed point is likely not perfect, and likely shows us just about any values for the match to start with?
So to answer your question, under these circumstances I never know what the condition is at the feed point, but I am going to try and change something if can, trying to find that perfect match...if possible. I'm not looking for the wrong results unless that can help. I'm looking for the perfect match, and when I find it...the length of the line won't matter.
Can we also agree that the rule that governs the 1/2 wavelength theory
is based on what happens at a point 180* degrees
BACK from the feed point of a perfectly matched load, where we can see indicated R=50, X=0, Z=50? Will you also agree in this case, a random feed line will show the same perfect results at any point along the line?
The bold print indicates a distinction that I suggest are generally ignored in considering the use of an electrical 1/2 wave tuned line for tuning...as having special features and providing special information. I think you will find similar claims in Reflections II, Maxwell's book on transmissions, among others. I don't have a link at the moment, but if I find it, I'll post it.
And, if this is true so far, and we cut a coax at some desired special tuned length, and we connect it to this unknown and mismatched load...we can expect the results to show us some stragne results...simply because we don't have a perfect match.
IMO, this conditions is due to feed line transformation, and considering the rule above is based on the load being perfect...we will not get any good information in this process and what significance is the values we see anyway. As soon as we make some guess as to change the matching device, the values change again, maybe worse or maybe better. We are no better off than we woud be using a random line at this point.
To be fair, at this point I am just trying to get lucky and make the right move, and if the rule is true you can do the same using a random length of line just about as easy as you can with a tuned line. This is because neither line will provide helpful information or guidance to what to do next, and as line length effects go you are only within a 1/4 wavelength, 90* degrees either way from your perfect match...if a perfect match is possible, and with a feed line attached to an end fed vertical...that ain't likely either.
How will you ever know if a perfect match is truly possible with a newly constructed antenna? The only real way to know for sure what is going on at the feed point of any antenna is to check it at the feed point, and thus you remove possibly the worst variable attached to that area, mainly the feed line.
You can test these effects simply by changing the feed line length, and if you see your results change, then the feed line is effecting the match, and those results may be close and don't matter much, but they are not perfect like the theory is based on. Plus the more the mismatch the more this is evident.
The main truth of this is in the rule too: if you have a perfect match then any length will indicate the same load impedance results at any point along a line of any length, excepting maybe for a small amount of wire resistance as your line gets longer.
If you have questions please ask, maybe I can explain better. This should be a simple idea, and most guys I talk to agree with you...the idea is simple and straight forward, just cut the coax to the desired frequency and it will show you correctly what the match is at the other end of the actural load. I would ask right here, even if you were lucky and the results were as noted above...what do you do with this information, what does it tell you. All it can possibly indicate is that the match is not what you wanted at this point. It might be worth writting down somewhere and compare it to another setting you might try. Most guys can't even tell which way they have to go with their matcher...that is why tuning instructions suggest we go both ways to test. Even then many won't likely get the implications.
I just don't agree and think most guys ignore the theory as stated, what happens if the load is not perfect. IMO most antenna loads are not perfect and are at best maybe close, even though guy's claim they see a perfect SWR.
