I have done tons of reading and can't seem to find an answer.
I have a 102" that I put on the roof. Coax started out 17' or 18' but I cut it when I made the inductor. It is now about as short as it took to get to the antenna from the radio (approx. 9' or 10'). Cutting the coax didn't change SWR (as some have said). The terminal connectors that attach the coax to the antenna are all soldered not crimped. It is mounted on a 6" barrel spring, and ball mount.
With the power at minimum (Galaxy 95t2) the SWR needle doesn't hardly move. Power at max (30W DK) the SWR was 1.5 on all (11M) channels. I moved the band selector and keyed up ONLY long enough to get a reading. SWR goes up the further from 27 Mhz I get, in either direction. So it is flat on 11M. Being flat means that physical lenght of the antenna is correct. I made an inductor coil and put it at the feed of the antenna and it brought me down from 1.5 to 1.3 with power at max.
I want it lower because I saved for months and bought an amp for my radio and I need to not smoke it. SWR seems to increase as power increases (as described below). Any ideas on how to get it down? I don't have an analyzer to calculate coax length, or see resonance, etc. All I have is an SWR meter.
Also, it seems that SWR increases slightly as the power increases. What would cause that? The radio was tuned on a scope, no clipping, not over modulated, no excessive output. My DK is actually 10W lower on high than the recomended 40W. As a sidenote, my SWR rose when I bonded my truck with gound strapping, why? Also started hearing added static and engine noise on my radio.
(bonding as follows- radio bracket bolted to cab floor, 2 straps from hood to cab, 2 straps from cab to frame, 2 staps from cab to bed, 2 straps from bed to frame, 1 strap from bed to tailgate, 1 strap from frame to exhaust tailpipe.)
I do not just want to get the answer, I am trying to understand the how and whys.
