Cheech,
You're right, more answers/comments than you'll want to see! LOL
The 'real' question is, "Could it/should it make a difference?", and the answer is yes it can, and no, it shouldn't. Thinking in terms of efficiency and good design, the feed line (jumpers) should not make any difference because the inputs and outputs should all be the same impedance as well as the feed line's. If the input/output (or the impedance on both ends of the feed line or jumper) are the same then there is no difference in what the length of the feed line is.
A difference in impedance between the input and output means there is some reactance in the feed line and that means a reduced efficiency. Power isn't developed in a reactance (or transfered) and that means you want as little as possible. There will always be some reactance, but not much, hopefully.
Any feed line has a characteristic reactance, some value of capacitance and inductance, and those 'values' depend on the frequency of use. In a well tuned/designed system they are kept to a minimum. Reactance isn't always 'bad', but when dealing with the transfer of power it is.
PS - Is there a formula for determining the length of jumpers/feed lines? Not as such, but yes, you can figure whats the 'best' length to use by knowing and using the accumulated characteristic capacitance and inductance of the jumper's or feed line's length. I'm too lazy, I ain't going there...
