Retevis is giving away Radios for the New Year and Every Member is Eligible. Click Here to see the details!
Need help with wire schematic.turner plus 3 silver faced blue,black,yellow,red,shield color wires to a ranger ar 3500 with 8 pin mic.I can not find any info on the net,figured someone here could help,please.thanks.
Do you need the schematic of the amplifier circuit board or do you want to know how to wire to your radio?
I traced out the board 20+ years ago but no idea where it may have gone. Rest assured the active components are long ago obsolete and NLA...
The wire colors are somewhat irrelevant. Whatever wire the shield wraps around is the mic audio line. Use a multimeter to see what wires connect together during transmit and then what are connected during receive. From there you need to determine how the AR3500 is wired.
Figure out how both ends work and connect A to B. Should be easy enough...
