Turner Plus Three Desk Mic wiring for an RCI 2980 4 pin...
danmcclain
I Support WorldwideDX.com!
Dec 11, 2020
877
466
Looking to wire my Turner Plus Three for use on an RCI 2980. Anyone got the color code and 4 pin layout for an RCI 2980 Base Station? Thanks, Dan
I just looked up both.... the RCI 2980 pin assignment is as follows
1 - Audio Shield
2 - Mic Audio
3 - XMT control
4 - RCV control
Now, the color code I see on the Turner Plus 3 mic is....
Mic Audio - WHITE
Mic Shield/Gnd - SHIELD wire
XMT - BLACK
RCV - RED
So I would say
SHIELD wire to pin 1
WHITE to pin 2
BLACK to pin 3
RED to pin 4
should do it.
Thank you guitar_199 for your prompt reply. I will be able to use my Turner Plus Three mic now...
guitar_199...Followed the wiring instructions you provided, instead of a white wire there was a yellow wire, so soldered all the wires where they go and that left one pin for the yellow wire. A successful job...the Turner Plus Three is working perfectly...Thanks again. Now have a Turner Super Sidewinder I need to wire to a radio, just haven't decided which one yet...
Glad to hear it Dan. Hope you get many a QSO with that mic.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
