TYT TH-UVF9 programming issues
Robb
Honorary Member Silent Key
I Support WorldwideDX.com!
Dec 18, 2008
11,432
3,668
323
Silicon Valley CA, Storm Lake IA
Someone gave this radio awhile back. Battery is dead as a door nail, but a Baofeng battery slips right in and works just fine. The radio is the 220/440 mhz version.
So, I thought I would see if I could program it via the cable. I'm using the same cable as the Baofeng UV-5R, and it worked before when I programmed the TYT and recently worked on reprogramming a UV-5R as well.
Of course, Win10 has a hissy fit over the cable not having a genuine Prolific chip in it, so I used a driver for the comm port that worked with the Baofeng with no issues.
CHIRP doesn't work for this model of the radio, so I downloaded and security scanned the 'F9' programming software directly from the TYT website:
https://www.tyt888.com/?mod=download
But for some unknown reason, it cannot communicate with the radio when I try to get it to read.
Is there a special driver for this radio that I am unaware of? Or does the radio have to be in any particular mode? Do I really need to do anything different? Someone had the same issue that I have?
Thanks in advance
