Uniden 858 pll 27.415 - 27.445
mr_fx
Oct 8, 2011
1,536
172
173
Kansas City
I have recently followed all the walk-thrus to open up my TRC-458, however I am confused by this one
27.415-27.445
Realistic TRC-458 26.045 to 28.045mhz expansion
27.415 TO 27.445mhz Expansion:
Very hard modification to find information on:
This modification should open up ALL the A-Channels,like
26.995mhz / 27.045mhz / 27.095mhz / 27.145mhz / 27.195mhz
(1) Cut trace going too pin #
(2) Solder a 4.7k resistor across this cut.
(3) Install a SPST switch
(4) Solder top pin of switch to 8 VDC ( RX AND TX )
(5) Solder bottem pin of switch to pin #17
(6) Solder bottem pin of switch to circuit board ground.
A few issues I see:
1.) step one does not list a pin number... but common sense tells you it is # 17
2.) it tells you to solder pin 17 and chassis ground to the 'bottem' pin on a SPST switch
3.) it THEN tells you to solder 8 volts DC to the top pin on the SPST
4.) if you did this and used that switch, wouldn't it cause a dead short?
5.) correct me if I am wrong but doesn't the Uniden 858 PLL use 5v on the pins?
