Im messing with another Uniden PC 122 radio I have here. There was no audio to the speaker so I baught a new audio chip well that wasent it problem still exists . My question is if the large value coupling cap is bad I know itwont let audio to the speaker but will there be regular audio or modulation to the finals as this one is?? What is the propper way to test these caps for a short using a multimeter??? I have a Capcitor tester but dont know where it is at the moment or if its even for this type of use all I know is its a Beckman. I was also had read that another problem could be the squelch device a clamp transistor is connected to the audio chip and if bad wont let audio to the chip. where would this be??? The speaker is fin because the radio has been tested with an external speaker also. I know there was pa modulation also so with all that there isnt much more that could be wrong or could go wrong to create this problem Thanks Tony....
