I drive a tractor-trailer and have been having trouble with achieving a low and stable SWR on a new tractor despite the fact that other drivers with new tractors are not having trouble.
After much experimenting and disappointment, I discovered that the only way to get an acceptable swr is to have weight on the fifth wheel of the tractor. It doesn't appear that just contact between the tractor and trailer will solve the problem but actual pressure on the suspension. I keyed up while hooking a trailer last night and watched it go down to around 1.5 on channel 20. Without a trailer I get over 2.0 and sometimes 2.5 or more. Any ideas?
A few details:
2014 Mack Pinnacle daycab tractor
Various 13'6" van type trailers.
Francis 4.5' antenna.
Coax is 18' clear mini-8 from the truck stop.
Mount is on grab handle above window behind the cab.
The above setup has worked very well for me in the past.
Thanks.
A few details:
Thanks.
