hey marconi, wanna run this on your eznic? begining with a verticle centerfed 1/2 wave dipole in the center the top of the dipole turns left (the bottom turns right) 90 degrees and goes horizontle for 1/2 wave then turns 90 degrees again and goes verticle down 1/2 wave then repeats, 90 to horiz then 90 to vert until you have 4 horizontles and 4 verticles on each side, but looking down on it looks like a 90 degree V in the direction you want the signal to go like a v-beam made like a zig-zag 'net'.
a friend of mine came up with this idea on the air yesterday so I thought id ask what you could do with it on your eznic
so like this
.....__.....__.....__.....__
|__|..|__|..¦__|..|__|..| about 144 feet wide before bending 90 degrees forward from the middle
but not flat across the front but in a forward V at 90 degrees toward the receiving station from the driven centerfed dipole in the middle
i want to know the gain of both the verticle and horiz and the pattern
brad 049 was saying it should do both with about 6dbd gain but he said hes just guessing
so like this
