Ok, I have to run this by you guys. Maybe one of you has seen something like this before. I recently came across a D & A Raider amp. Since I wasn't familiar with it, I started researching it hoping that to learn more about it. I discovered that this amp was created to be an 11 meter only amp. Despite the fact that the selector switch on the front says 10/15/20 & 40 meters on it . But here's where it gets interesting. The original D & A Raider amps had a small coil inside them, roughly about an inch long. And only one wire coming from the selector switch ... but this one has been modified. The coil inside this one is around 5 or 6 inches long (give or take an inch) , with a wire coming from each section of the selector (10/15/20 & 40) and attached to the coil in the appropriate sections for the matching frequencies on the selector.
So apparently, someone has taken the time to restore this D & A Raider, and also modify it to actually work on the bands that the selector on the front says.
So have any of you ever seen a D & A Raider with a modification like this before ? Because I haven't had any luck trying to find out any information about this on the Internet.
Incidently, before it's commented on. Yes I am licensed to use it on the HF bands. I'm just curious about the modification, it's the only one I've seen like this.
