I came across a radio parts list that contains "solid aluminum electrolytic capacitors". Historically, what has been the experience from those in the "know" about these solids as compared to non-solids. Should we be replacing these with non-solids or leave be? I want to make sure I do not overlook these items if required in my kits.
Quotes from Wiki:
"Aluminum electrolytic capacitors with non-solid electrolyte are the best known and most widely used electrolytic capacitors. "
"Types with solid manganese dioxide electrolyte have served in the past as a "tantalum replacement"
"Most modern aluminum electrolytic capacitors with non-solid electrolytes nowadays are very reliable components with very low failure rates, with predicted life expectancies of decades under normal conditions."
Quotes from Wiki:
