Here is an interesting antenna, I drew it up with measurements for 11m. Hope to get one in the air soon as I can. it emits at a low angle towards the horizon, about 26 ° (effectively 20 – 40 °), it has vertical signal polarisation, and the antenna gain is about 3 dBd! The antenna does not require a Balun and, most importantly, high masts. The radiation pattern is almost circular, the maximum radiation/gain point exists in the direction of the longer wire –
