W8JI has posted an informative article on his site that is worth reading:
"QST The Care and Feeding of a 3-500ZG filament
Regretfully the October 2011 QST, on page 40, contains a fatally flawed filament voltage management article. Without question, the QST article gives life-threatening advice. The article specifically instructs readers to remove a protective cover and intentionally defeat a safety interlock by placing the reader's hand only inches from lethal voltages. The article further instructs readers to look away from their hand while high voltage is active.
There is never a reason to defeat a critical safety protection system and activate lethal voltages with protective covers removed. Anything determined with the cover removed can be more safely accomplished with the cover in place, or with power removed. This is true for all problems.
Besides safety, the article's instructions will almost certainly lead to improper equipment operation or tube life problems. Nearly all instructions in the QST article, as well as all technical information in that article, are wrong for any brand or type of amplifier."
Read more here
Read more here
