B
BOOTY MONSTER
Guest
let me warn you up front......ive had too much spare time today and ive ben thinking . :twisted:
a 102 inch (9 foot) antenna is a 1/4 wave antenna on a mobile . soooo.a 204 inch (18ft) is 1/2 wave and 408 inch (36ft) is full wave . is that correct?
if so.....(if im wrong read no further as it dosnt matter ...lol)
most mobile antennas have coils to reduce the physical length of them . now........if you took the basic design of the open air coil antenna (10-k,mm,coily but mostly 10-k because of reduced wind load and weight)and made it one big series of coils from top to bottom couldnt you make a full wave antenna for mobile use that isnt too tall for most vehicles ? isnt 1/2 better than 1/4 ?5/8 better than 1/2 ? and full wave better than 5/8 ? the bigger the antenna the stronger the signal ?(assuming its tuned to the correct band)
im sure theres got to be something wrong with doing it or somebody would be making them . :shock: :shock:
