water power
but it takes alot of power to seperate water.
That is what I was thinking. I know you can break water down to its basic compounds, but how much power do you have to put into it, for the amount of power you get out of it?
If they can get that problem solved, this looks like a great power source.
yea, and a lot of times people pay $1 for a 1/2 liter of water today.
Hey..
It is Indeed a great idea..
a Great way to lessen our needs for oil and gas..
although it can be Expensive to set up..
it is not as Expensive as one is led to believe..
the process is already being used by i think mobil
and they use solar cells to provide the electric needed to seperate out the hydrogen..
another spin on this process is the use of a fireplace that runs on hydrogen from water..and this process does not need any venting of fumes...since only by product is oxegen and or water..
now the real question should be..
we us common people gain benifit from these low cost and exellent fuel sources..
or will it be told it is imposible and or far to expensive and or far too dangerous to do..
time will tell
Later
boy,that would put the arabs in a whole bunch of trouble,kinda change the tables,one thing they aint got there is water.lol
    535A has left the room.
  • @ AmericanEagle575:
