Weather Proofing Mobile Atenna Connections
ctvanover
N/A
May 22, 2005
161
7
61
Archdale, NC 27263
Is there a way to weather proof mobile antenna connections, such as the coax to the so239 bottom side of the mirror mount and the so239 to the antenna on the top side of the mirror mount? Would a high temp silicone do the trick or maybe some heat shrink? Come guys give me some advice, any and all will be greatly appreciated!
Radio Shack use to have somthing called Coax Seal. It was a black sticky tar like tape that you could shape with your fingers and press it tigbtly around the coax ends and connections. Worked real well, I have used this in the past with success.
Coax seal, great stuff as well. Heres a hint, wrap electrical tape with the stucky side out then wrap the joint with coax seal. That way if you have to ever take the joint apart its easy and clean once the caox seal is off.
    535A has left the room.
  • @ AmericanEagle575:
