I have a Sirio 27-4 on top of a 25’ telescopic flagpole. Pole is 11 guage aluminum. Mast above rotor is non conductive, fiberglass + pvc. I wanted some kind of ground and lightning protection. Bought an alpha delta surge protector and 20’ of RG213 from dxengineering to run from my radio to the ground rod at the base of the old push up pole my Sirio 2016 is on. Mounted the surge protector on the ground rod connected the RG213 and the RG8X that goes to the antenna.
Check match barefoot all good. Check with RM 503 turned on no change with dead key of about 100watts. The kicker is when I modulate on AM or SSB reflective power goes crazy. I plan to replace the RG8X going to the antenna with RG213. Just wasn’t in the budget this month. Amp is good checked on my ground plane. But something is not right. Works fine at full power from radio. Which is all I use 99% of the time. Like I said in the title I have seen this before but can’t remember what the issue was then. I guarantee if I run the RG8X straight into the shack all would be fine.
